Delusional
- Phil
- Dec 5, 2019
- Pittsburgh
- F-150
- Construction
A few links.
https://eclipse.gsfc.nasa.gov/solar.html
https://www.timeanddate.com/eclipse/solar/2024-april-8
More maps here. Also be sure to check out the Annular Eclipse of October 14, 2023, which passes 100 or so miles south of Austin.
https://www.greatamericaneclipse.com/october-14-2023
It will be a good date to be in Austin. The total eclipse passes right through Austin and Austin is very near the point where it lasts the longest time. Totality will last over four minutes in Austin, which is very long, it is rarely over three minutes. If you miss this one, the next chance in North America is 2044, and again in 2045, unless you go to northern Alaska in 2033.
I figure my reservation number is about 224,000. If CT production starts in late 2022, they should be getting to my number somewhere near the date in question. If I get lucky, I might just opt to pick the CT up in Austin, even if they will deliver it to my home.
That way I can see the eclipse in an area with less probability of clouds. I have attempted to see total solar eclipses twice in my life, but it was obscured by clouds both times. The one in 2017 was exceptionally disappointing because there were only two clouds in the sky and one of them moved to exactly where I didn't want it to go. I saw the eclipse before totality and after totality, but not the best part.
