azjohn
- john
- Nov 21, 2019
- Henry County Virginia
- Toyota Tundra
Nikola is now in bed with GM
Interesting that Nikola is going to use GM batteries and HFC system meaning they essentially have nothing to offer. What innovation is coming from Nikola?Nikola is now in bed with GM
Nikola also has the business model of buying electricity when it's cheap (solar) and storing it in a moveable medium (hydrogen) without carbon emissions.
It doesn't matter that it takes more energy: The point is that it can be stored or put into trucks.I don't think this will work. It takes more energy to extract hydrogen(from whatever, hydrocarbons or H2O) than what you get out of it.
I have no idea how much tanks for hydrogen cost but they can't be cheap to make.Tanks for hydrogen aren't easy to make, but they are easier (and much cheaper) to make than batteries.
If that were the case it would have already happened.The kwh to kg of even low pressure hydrogen storage makes it desirable for big transport like trucks and ships because it doesn't displace carrying capacity.
I don't know how much they cost, but I know they weigh about 25-30kg for every 1kg of hydrogen stored. Nikola holds 80kg. The effective energy density of compressed hydrogen is only around 1,400Wh/kg not counting the weight of the HFC.I have no idea how much tanks for hydrogen cost but they can't be cheap to make.
Show me some figures on how much hydrogen storage tanks cost.
I'm also curious what will happen when one of these hydrogen trucks is in a bad accident. We could call it "the Hindenburg effect".
No, it isn't. Low pressure hydrogen has a very low volumetric density. High pressure hydrogen has a low gravimetric density. You either lose physical space or weight capacity.The kwh to kg of even low pressure hydrogen storage makes it desirable for big transport like trucks and ships because it doesn't displace carrying capacity.
And anyone else in the vicinity.Any crash that would puncture a tank would kill everyone inside instantly.
And if it does puncture, the gas escapes in seconds and rises in the atmosphere very quickly.
Even if ignited, it is far less dangerous than gasoline, diesel, propane, or a battery. It would burn off in seconds and be done.And anyone else in the vicinity.
If it's ignited watch out!
Good point. But because it is compressed it would cause dangerous shrapnel from the tanks when ignited and an explosion occurs.Even if ignited, it is far less dangerous than gasoline, diesel, propane, or a battery. It would burn off in seconds and be done.
Any pressure buildup in the tanks would open the over pressure valve and all he hydrogen would escape. And if that failed, composite tanks rupture, they don't explode.Good point. But because it is compressed it would cause dangerous shrapnel from the tanks when ignited and an explosion occurs.
